Date/Time: Mon, 29 Apr 2024 01:29:07 +0000
Keyboard Short Cut Configuration for Horizontal Rays
View Count: 1007
[2021-07-13 14:44:51] |
User226793 - Posts: 160 |
Folks, just need some help. For a horizontal Ray, i can have multiple configurations TC1 -- TC8. I would like to set up the configurations using "Keyboard Short Cuts"; Example: TC1 - Orange Ray--> Key Board Shortcut is "a". Tc2--> Yellow Ray --> Key board ShortCut os "s".. Can you please guide me through the process of setting this up?
[2021-07-13 14:57:35] |
User907968 - Posts: 802 |
Instructions - -> Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step -> Chart Drawing Tools: Keyboard Shortcuts for Custom Drawing Tool Buttons |
[2021-07-13 16:48:33] |
The first link above is the one you want.
[2021-07-15 20:22:07] |
Hi John, thank you. But i was looking to configure the 24 variations of horizontal ray with different colors using the keyboard, if that made any sense?
[2021-07-16 18:16:58] |
Then it is both links you want. The first one tells you how to create the Control Bar configurations to select the tool and configuration. The second one tells you how to create a Keyboard Shortcut for those Control Bar buttons.
[2021-07-19 12:28:25] |
John, sorry, im still running into the issue where i am trying to setup 10 keyboard shortcuts for Using Multiple Drawing Tool Configurations using Horizontal Ray as the drawing tool. I am happy to pay for a quick call if required or if you have a loom video showing how to do this, that would be much appreicated
[2021-07-20 12:55:39] |
[2021-07-26 14:45:42] |
The first thing you need to do is to create the Control Bar Buttons for the different configurations you want. Follow these instructions: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Then you create Keyboard shortcuts of the Control Bar buttons that you created by following these instructions: Chart Drawing Tools: Keyboard Shortcuts for Custom Drawing Tool Buttons Let us know where you are having an issue. We are not able to do phone calls for this kind of issue. If you need one-on-one help, then we recommend the following: https://www.buymeacoffee.com/dianapena For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
