Date/Time: Mon, 06 May 2024 06:43:17 +0000
No Eurex data feed
View Count: 512
[2021-07-02 09:47:20] |
User232758 - Posts: 6 |
Hi I don't have any Eurex data coming through this morning. I am getting CME and Comex. Thanks Mark |
[2021-07-02 10:54:58] |
Sierra_Chart Engineering - Posts: 14239 |
Restart Sierra Chart. This will resolve the problem for the time being. We can set your account to still use EUREX data from your current source for the remaining of this month. And refer to: July 1, 2021: EUREX Realtime Data from Denali Exchange Data Feed Policy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-19 09:03:09] |
Hi my backup solution(internet comms and hardware) depends on CQG, I also use Journalytix for my end of day journaling which interfaces directly with CQG. I will need to go for the package 10 with the external Eurex feed. Do I need to need to do anything else other than migrate to package 10 and the data feeds will stay as they are?
[2021-07-19 15:04:26] |
You just need to follow the instructions here: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX Do I need to need to do anything else other than migrate to package 10 and the data feeds will stay as they are?
Yes, and the EUREX data will then come from Sierra Chart.
[2021-07-19 16:41:47] |
Sierra Chart - Max - Posts: 5605 |
From User: Hi I need to continue using the Eurex feed as an external feed to the Denali feed otherwise I will have to pay twice for it to maintain access to it through my backup solution (Android with inbuilt 4g connectivity) which is there to close trades if I experience an equipment or internet failure. This configuration mentioned in a previous response is what I would like to opt for :- "So what we are going to do in the case of EUREX, is if you are on the Service Package 10 or higher, then it will not be necessary to activate the EUREX exchange fee access to still be able to access real-time EUREX data, from an external source other than the Denali Exchange Data Feed". I presume I just migrate to package 10 and continue on as I am doing ? Sierra Chart Support |
[2021-07-19 18:38:18] |
Yes this will be fine.
