Date/Time: Wed, 09 Sep 2026 09:15:35 +0000
Couple Questions
View Count: 1413
| [2014-03-16 15:55:07] |
| bmoney - Posts: 32 |
Hello Support, 1. I want to move a particular set of data from one installation to another, can this be done by simply moving the .scid files? 2.I connect to the CTS T4 data feed, however I have issues with the actual T4 platform program and would like to know if I uninstall/re-install it from my computer would this adversely affect my Sierra Charts, which connects to the CTS T4 data feed, in any way? Is the CTS T4 platform program completely independent from the Sierra Charts; there are no trace logs the T4 platform program records from sierra charts or anything like that? |
| [2014-03-17 00:32:13] |
1. Yes. Refer to this page for more information: https://www.sierrachart.com/index.php?l=doc/helpdetails15.html 2. Sierra Chart has no interaction with the T4 front-end platform itself. It is completely separate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
