Date/Time: Tue, 27 Oct 2026 08:37:04 +0000
Constant Waiting to reconnect (no live price feed)
View Count: 807
[2021-06-14 16:04:32]
User582434 - Posts: 1
Hi.
I've successfully connected the BitMex data feed to Sierra but two issues keep bothering me:
1. The Charts are not updating in real time
2. There is constant "Waiting to reconnect" yellow mode
Am I missing to do something? Thanks.
Here's the Message log:
Reading Internal Order ID file. | 2021-06-14 15:36:04.334
Reading Trade Orders file. | 2021-06-14 15:36:04.552
Reading Trade Positions file. | 2021-06-14 15:36:04.553
Reading Trade Account Data files. | 2021-06-14 15:36:04.555
UDPListener (616). Port 22904 | Listening on UDP port 22904. | 2021-06-14 15:36:04.677
Software version: 2270 64-bit | 2021-06-14 15:36:04.677
Primary Thread ID: 48 | 2021-06-14 15:36:04.677
Usage end date: 2021-07-30 | 2021-06-14 15:36:04.677
Enabled for: Sierra Chart Historical Data Service. | 2021-06-14 15:36:04.678
Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-14 15:36:04.678
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-14 15:36:04.678
Current selected Data/Trading service: BitMEX Trading Direct | 2021-06-14 15:36:04.678
Custom symbol settings values: enabled | 2021-06-14 15:36:04.678
Chart Update Interval: 500 | 2021-06-14 15:36:04.678
Intraday Data Storage Time Unit: 1 | 2021-06-14 15:36:04.678
Time Zone: +00:00:00 (UTC+00) | 2021-06-14 15:36:04.678
2021-06-14 15:36:04 Local computer time in UTC | 2021-06-14 15:36:04.678
2021-06-14 15:36:04 Local computer time in SC Time Zone | 2021-06-14 15:36:04.678
2021-06-14 15:36:03 Server time in UTC | 2021-06-14 15:36:04.678
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-06-14 15:36:04.678
Program path: C:\SierraChart\ | 2021-06-14 15:36:04.678
Data Files path: C:\SierraChart\Data\ | 2021-06-14 15:36:04.678
OS Version Number: 6.1 | 2021-06-14 15:36:04.678
Locale Setting: C | 2021-06-14 15:36:04.678
DLLs: UserContributedStudies_64.dll | 2021-06-14 15:36:04.678
Allowed protected custom studies: | 2021-06-14 15:36:04.678
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2021-06-14 16:00:07.820
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2021-06-14 16:00:07.820
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2021-06-14 16:00:07.848
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2021-06-14 16:00:07.849
BitMEX Trading Direct socket (2) | Connecting to IP: 34.242.242.25. | 2021-06-14 16:00:07.849
BitMEX Trading Direct | Opening WebSocket. | 2021-06-14 16:00:07.907
BitMEX Trading Direct | Sending WebSocket handshake. | 2021-06-14 16:00:07.907
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2021-06-14 16:00:08.081
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2021-06-14 16:00:08.081
BitMEX Trading Direct | WebSocket closed. | 2021-06-14 16:00:08.081
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-14 16:00:08.081
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-14 16:00:08.081
BitMEX Trading Direct socket (2) | CloseSocket call. | 2021-06-14 16:00:08.092
BitMEX Trading Direct | WebSocket closed. | 2021-06-14 16:00:08.092
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:00:08.092
BitMEX Trading Direct | Disconnected. | 2021-06-14 16:00:08.092
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-14 16:00:08.092
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2021-06-14 16:00:08.147
BitMEX Trading Direct socket (2) | Closed. | 2021-06-14 16:00:08.147
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2021-06-14 16:00:11.093
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2021-06-14 16:00:11.093
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2021-06-14 16:00:11.094
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2021-06-14 16:00:11.094
BitMEX Trading Direct socket (1) | Connecting to IP: 52.51.198.178. | 2021-06-14 16:00:11.094
BitMEX Trading Direct | Opening WebSocket. | 2021-06-14 16:00:11.149
BitMEX Trading Direct | Sending WebSocket handshake. | 2021-06-14 16:00:11.149
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2021-06-14 16:00:11.315
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2021-06-14 16:00:11.315
BitMEX Trading Direct | WebSocket closed. | 2021-06-14 16:00:11.315
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-14 16:00:11.315
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-14 16:00:11.315
BitMEX Trading Direct socket (1) | CloseSocket call. | 2021-06-14 16:00:11.327
BitMEX Trading Direct | WebSocket closed. | 2021-06-14 16:00:11.327
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-14 16:00:11.327
BitMEX Trading Direct | Disconnected. | 2021-06-14 16:00:11.327
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-14 16:00:11.327
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2021-06-14 16:00:11.380
BitMEX Trading Direct socket (1) | Closed. | 2021-06-14 16:00:11.380
Date Time Of Last Edit: 2021-06-14 17:29:07
[2021-06-14 17:27:56]
We cannot help with this:
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2021-06-14 15:59:12.795
Do not connect to BitMex directly. Just use the market data only according to the instructions here:
Cryptocurrency / Bitcoin Data and Trading Services: Setup Instructions
Date Time Of Last Edit: 2021-06-14 17:28:40
