Date/Time: Sat, 04 May 2024 05:30:31 +0000
DELTA settings with absorption indicator
View Count: 1516
[2021-06-11 08:42:42] |
User554446 - Posts: 29 |
Hi, I have a question about the delta settings. I have this indicator that shows the delta with a cluster or 350 ticks and with a filter that swos just delta above the 350 value. Is that possible to setup something similar in Sierra. I Found it very powerfull in order to spot absorption. Thank you so much! Best Regards. Andrea |
Screenshot_from_2021-06-10_16.12.482x.png / V - Attached On 2021-06-11 08:42:10 UTC - Size: 74.09 KB - 606 views |
[2021-06-11 17:22:51] |
John - SC Support - Posts: 31362 |
Yes, you can do this using the Numbers Bars and setting the colors and the thresholds in a way that only the highest value would show (i.e. setting the other colors the same as the bar coloring). Refer to the information for Numbers Bars on this page: Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
