Date/Time: Mon, 06 May 2024 09:34:38 +0000
New Futures Account AMP
View Count: 468
[2021-06-02 16:22:21] |
Michael Slater - Posts: 15 |
Hi I have just opened a Futures account with AMP Futures. Please advise is there any additional documentation that I need to execute with Sierra to activate trading from Sierra Charts within AMP? Thanks |
[2021-06-02 17:30:06] |
John - SC Support - Posts: 31379 |
The first thing you need to do is to setup your Sierra Chart to connect to your CQG account (AMP should have set you up with CQG for your order routing). To do this, follow these instructions: CQG Trading Platform Service: Setup Instructions After that is done, the open your Chartbooks and select Edit >> Translate Symbols to Current Service in order to change your symbols to the CQG symbols. Finally, it's just a question of real-time data. If you are getting your data from CQG, then you should be all good at this point. If you want to get your data from us (Sierra Chart), then refer to the information on the following page for data from the CME Group and EUREX: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
