Date/Time: Fri, 03 May 2024 23:41:02 +0000
problem with data from EUREX
View Count: 465
[2021-06-01 16:38:38] |
User661695 - Posts: 5 |
Hi, I've an active account on AMP with Eurex data enabled, but today I can't get eurex data on sierra. Error code attached. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=51453 |
[2021-06-01 17:23:59] |
John - SC Support - Posts: 31362 |
Make sure that AMP has not turned off your EUREX data feed. That message implies that you are not able to get the data from CQG.
[2021-06-01 21:16:24] |
We have found that there was a misunderstanding, so CQG needs to reenable the data. They should have this done right away, but worst case it will be tomorrow morning.
[2021-06-01 23:10:14] |
Sierra_Chart Engineering - Posts: 14207 |
CQG has restored the EUREX data for Sierra Chart users. If you do not have real-time data for that exchange now, reconnect the data feed following these instructions: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
