Date/Time: Mon, 29 Apr 2024 00:10:27 +0000
DOM P&L issue !!
View Count: 361
[2021-06-01 16:17:02] |
Honore_Sierra - Posts: 2 |
Hi, Currently, I have a DOM P&L print issue. I can see Closed PL = -21 Ticks instead of 0 Ticks. I did not understand why I can have -21 Ticks today ( june 1st 2021) as I did not any order postion or any trade. And from yesterday may 31th, I have a Closed PL= 0 normaly. Could you please have a look/check and help to fix this issue ? Many thanks in advance for your help/support. Let me know please. BR, |
[2021-06-01 16:39:19] |
User310645 - Posts: 49 |
Mine too. Trade activity log is fine but the chart trade window DPL is all over the place. Tried installing older versions 2247-2268 all same.
[2021-06-01 17:24:45] |
Refer to the following: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-01 17:53:20] |
I have my trade window linked between two charts. I checked "Load order fills for current day only" and once I had done the second chart it started working and reset the DPL. Never had to do this before but hey ho as long as it works now. Thanks
