Date/Time: Mon, 06 May 2024 23:00:34 +0000
Flux Denali
View Count: 707
[2021-06-01 11:00:27] |
Utilisateur188232 - Posts: 22 |
Bonjour, j'ai activer le flux denali, est ce que j'ai besoin de payer le flux eurex et cbot pour avoir des données en temps réel ? car je n'ai pas les données en temps réel avec le flux denali ? Merci de votre réponse. |
[2021-06-01 14:56:33] |
John - SC Support - Posts: 31413 |
From Google Translate: Hello, I have activated the denali flow, do I need to pay the eurex and cbot flow to have real time data? because I don't have the realtime data with the denali stream?
Thank you for your reply. You have not completed all of the steps necessary to fully setup the Denali Exchange Data Feed. In particular, you need to activate an exchange for the EUREX. Be sure you go through the remaining steps for the EUREX data, starting here: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_ActivateTheExchanges_EUREX And, if you are interested in data from the CME Group (you mention CBOT), then you will need to go through these Setup Instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
