Date/Time: Sun, 05 May 2024 12:54:28 +0000
login disabled...contact your FCM
View Count: 1554
[2021-06-01 00:03:26] |
User183724 - Posts: 183 |
login disabled...contact your FCM? what is a FCM and how do I contact them?
[2021-06-01 08:18:32] |
Sierra_Chart Engineering - Posts: 14230 |
You need to contact your broker about this. For now what you want to do is set Global Settings >> Data/Trade Service Settings >> Current Selected Service to "SC Data-All Services". And translate the symbols: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-01 08:22:57
