Date/Time: Sun, 05 May 2024 15:14:14 +0000
Denali Data Trial
View Count: 399
[2021-05-31 16:38:46] |
Patocalypse - Posts: 2 |
Hello, I am looking to make the switch to Sierra Charts for my live trading. I want to be sure I can get the charts setup to meet my needs with all the features. The last time I had been in the market to switch platforms, the Denali Data feed was not around. Would it be possible to get a trial of the denali data so that I can setup my chartbook and see how the data feed works? Thanks, |
[2021-05-31 17:02:55] |
John - SC Support - Posts: 31364 |
If you have not used the Denali Exchange Data Feed in the past, then the first exchange that you activate is free for the remainder of the month in which you activate it. The data feed fee, however, does not have a trial, but you only pay for what you use. To setup the Denali Exchange Data Feed for the CME Group data, refer to the following instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you need data for the EUREX, then you would follow these instructions: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
