Date/Time: Wed, 08 May 2024 20:45:08 +0000
Delayed Data on Crude (CLM21-NYMEX)
View Count: 435
[2021-05-17 16:05:21] |
User938282 - Posts: 2 |
Hello, is there any problem in data for NYMEX? I have delayed data now.
[2021-05-17 18:04:52] |
John - SC Support - Posts: 31475 |
There is no issue with CL at the moment. If you are still having an issue, then follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
