Date/Time: Mon, 29 Apr 2024 20:00:09 +0000
How do I connect my Sierra Chats platform to AMP
View Count: 489
[2021-05-15 09:50:06] |
Natalia Lungu - Posts: 1 |
Hi There I have a denali data feed setup with Seirra chats and I have talked to AMP, they have provided with my CGQ credentials for connecting the trading account. I cant seem to work out how or where to connect to CGQ. So its data feed = denali, trading account = amp (with CQG creds) Any help would be greatly appreciated Natalia |
[2021-05-16 01:14:26] |
Cullenm2007 - Posts: 1 |
I am a new SC and AMP user as well. I was able to go into "Data/Trade Service Settings" window on SC and then on the top row under "Service" and "Selected Service" I was able to select "CQG WebAPI [Trading]" as my option and then enter my credentials under service settings and that does seem to work. But I honestly cannot answer if the data feed I am receiving is CQG or Denali, but trading does work that way and my AMP account is connected.
[2021-05-17 14:21:30] |
John - SC Support - Posts: 31187 |
To connect your Sierra Chart to CQG, refer to these Setup Instructions: CQG Trading Platform Service: Setup Instructions Then go through these instructions to ensure that you are properly connected to the Denali Exchange Data Feed: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services The above also gives information on how to know that you are connected to the data feed coming from Sierra Chart. Then, just to ensure that you have everything setup fully, open your Chartbooks and select Edit >> Translate Symbols to Current Service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
