Date/Time: Wed, 22 Jul 2026 16:28:55 +0000
TICK-NYSE data on charts
View Count: 1464
| [2014-03-11 21:09:46] |
| User46567 - Posts: 8 |
Hi there Forgive me if this is a silly question. Is it possible to have the TICK-NYSE data integrated onto the chart similar to how the volume is attached at the bottom? I am able to pull this as a seperate chart but this makes my layout messy. Thanks a lot in advance. Olly |
| [2014-03-12 04:39:43] |
This is explained here: https://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php#Overlaying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-03-12 14:26:36] |
Hey thanks - this is exactly what I meant. Thanks for the rapid support! |
