Date/Time: Wed, 08 May 2024 10:36:46 +0000
Switch from Denali to Rithmic
View Count: 856
[2021-05-12 23:39:18] |
User852621 - Posts: 14 |
Hi, I want to switch from Denali to Rithmic data feed since I want to use Jigsaw. I asked AMP about this, and they told me this was done by Sierra now. Thanks. |
[2021-05-13 13:59:08] |
John - SC Support - Posts: 31441 |
We are not supporting the current Rithmic integration. We are waiting for them to release their new interface, at which time we will support them again. Therefore, you really need to wait for this new interface before you can use Rithmic with Sierra Chart.
[2021-05-13 17:50:36] |
I'm aware of that, was planning to use the old bridge. If you don't want to do that... what's my other option? Cancel everything I have with Sierra and ask AMP again? |
[2021-05-13 18:50:46] |
You can use the old bridge files at your discretion. You will find them here: Rithmic Bridge Files The other option would be to use CQG with AMP. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-13 19:08:18] |
It will need to be Rithmic because I want to share the connection with Jigsaw and Sierra Can you set that up then? Thanks. |
[2021-05-13 20:35:52] |
Just follow these instructions to turn off the Denali Exchange Data Feed: Denali Exchange Data Feed: Canceling the Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-13 20:54:32] |
Done, what next?
[2021-05-13 21:39:26] |
That's it from our end. If you have not already done it, then you need to select Rithmic as your Trading Service in File >> Data/Trade Service Settings and then enter your Username and Password. You would also need to install the Bridge files we referenced previously. Otherwise, everything else is up to your broker to get you setup with Rithmic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-14 00:35:32] |
Done, thanks.
