Date/Time: Sat, 04 May 2024 16:01:24 +0000
Which data feed do I need in order to connect the platform to my AMP account
View Count: 365
[2021-05-12 08:42:17] |
Gabriel2018 - Posts: 5 |
Hi, as Rhithmic is no longer supported by SC to what data feed do I need to connect in order to trade my AMP Futures account and be connected to them? Thanks
[2021-05-12 15:06:21] |
John - SC Support - Posts: 31362 |
We think you are actually asking what Trading Service would you use. With AMP, the only option right now is to use CQG for your trading service. You will need to ensure that AMP has you setup with CQG. Once they do, then follow these instructions to connect your Sierra Chart software to CQG: CQG Trading Platform Service: Setup Instructions In terms of data, we recommend using the Denali Exchange Data Feed for CME Group and EUREX data. Refer to the following, which includes Setup Instructions on the page: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
