Date/Time: Tue, 07 May 2024 19:52:58 +0000
Time Scale in Footprint chart wrong
View Count: 450
[2021-05-12 08:26:25] |
maxm1987 - Posts: 104 |
Dear community - another basic question, all I want to do is have all of yesterday from 9:30-close displayed on my screen .. nothing more, nothing less .. the scale range is set to constant range (but when I set it to automatic I have the same problem just presenting itself slightly differently). My problem is when I click and drag the time scale to scroll to yesterday’s open the chart jumps back all the way to May 7. When I set the scale to automatic it jumps back to May 7 as well and crunches up the numbers completely. Is there a simple trick to only display yesterday without any jumping? |
SC_Scale.JPG / V - Attached On 2021-05-12 08:10:12 UTC - Size: 352.96 KB - 170 views |
[2021-05-12 15:03:49] |
John - SC Support - Posts: 31437 |
We do not know what you mean by Jumping, but if you just want to see a specific day in the chart, then the best way to do that is to use the Date Range option and set the same date for the From/To fields. Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-15 07:10:46] |
Also make sure this setting is set to 1: General Settings Window: Scroll Multiplier (Global Settings >> General Settings >> GUI >> Scroll) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-15 07:10:56
