Date/Time: Fri, 03 May 2024 22:32:53 +0000
SET UP of AMP FUTURES
View Count: 5603
[2021-05-11 16:18:24] |
samueljohnson37211 - Posts: 1 |
please advise the best set up for AMP Futures CBOT
[2021-05-12 14:15:53] |
John - SC Support - Posts: 31362 |
We do not understand what you are asking. Our best guess it that you are looking for the Setup Instructions to connect to your trading service, which with AMP should be CQG. If this is the case, then refer to the Setup Instructions here: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-12 21:08:49] |
You will want to have AMP set you up with a CQG account for trading and these are the instructions to connect Sierra Chart to that account: CQG Trading Platform Service: Setup Instructions We recommend that you use our Denali Exchange Data Feed instead of the data feed from CQG and only use CQG for order routing. You will want to use Sierra Chart Service Package 10 or 11. For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-12 21:09:06
[2022-01-09 15:15:26] |
User730246 - Posts: 2 |
Why You recommend to use Denali Data Feed in stead of CQG feed given by AMP? Is it some difference between these two?
[2022-01-10 01:09:18] |
The historical data is superior in every way, and the market depth data is properly provided. The data is also processed more efficiently on a background thread.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-10 01:09:34
[2022-02-28 21:03:47] |
User755165 - Posts: 9 |
How can I connect Sierra with AMP account when using Denali Data Feed please?
[2022-02-28 22:16:44] |
Sierra Chart is specifically built to do this. Refer to the instructions here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
