Date/Time: Tue, 07 May 2024 06:24:35 +0000
Setting 2 OCO attached orders
View Count: 376
[2021-05-08 19:34:35] |
User645832 - Posts: 99 |
In a situation when I trade a range break I wish to set two pending orders, a Buy Stop order and a Sell Stop order, each order is a bracket order with a stop and a target, is it possible to set them in such a way that if the Buy order is triggered the Sell order will be canceled and vice versa?
[2021-05-10 15:39:42] |
John - SC Support - Posts: 31419 |
There are no built-in order types that can do what you are asking. You may be able to accomplish what you want with the Spreadsheet Study for Trading, but honestly, it sounds like you would be best off looking at the specifics of when you are placing one order versus the other and then just entering that order based on the conditions. Depending on the complexity of your requirements, you may need to use ACSIL for it. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading And the following: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
