Date/Time: Sun, 28 Apr 2024 05:40:10 +0000
Add small exchange symbols from IB
View Count: 449
[2021-05-06 07:14:25] |
User190501 - Posts: 92 |
Denali doesn't support Small exchange. How can we add the Small exchange symbols manually from Interactive brokers to be charted at Sierra chart ?
[2021-05-07 02:30:22] |
You can open charts for them following the specifications here: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-08 09:58:27] |
Which section of the provided link is related to the new "Small Exchange", Can you provide an example ?
[2021-05-10 14:41:06] |
You would have to ask Interactive Brokers for the format to use.
