Date/Time: Sat, 04 May 2024 06:31:40 +0000
Interactive Broker order stuck on PendingModify after entry
View Count: 715
[2021-05-05 09:11:17] |
User735389 - Posts: 188 |
Im using ascil to enter and manage order entries through IB. My order usualy consists of a limit entry, stop, and 2 target limits. after an entry is made, the order is sometimes "stuck" in the pendingmodify state (or some other pending state). At which point im just waiting for the state to change to open before allowing for any other modification (which i assume is the correct way to handle this). The time in which it correctly changes from the pendingmodify is inconsistent. Sometimes it changes nearly instantaneously. More often it doesnt seem to ever change. This resolves itself if i restart the IB app, but this isn't much of a resolution since i often change the targets/stops after order entry. I understand this might be an issue with trade station, but is this an issue you guys have seen? Do you have any recommendations to resolve? |
[2021-05-06 03:41:50] |
Sierra_Chart Engineering - Posts: 14207 |
This is just one of these common problems with Interactive Brokers. We absolutely do not recommend using it for automated trading. Refer to: Interactive Brokers Trading Service: Trading Related Issues If you are trading US futures, we recommend this service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-06 04:18:19] |
got it, thats unfortunate. i have to use them since i trade a mix of fut and stocks. did i read correctly that you guys were considering have your own stock/crypto trading service? not sure if im remembering that correctly from a random thread
