Date/Time: Sun, 28 Apr 2024 16:21:14 +0000
Cumulative delta bars Volume right-side
View Count: 1918
[2021-04-30 20:03:43] |
User628616 - Posts: 132 |
On the Study: Cumulative Delta Bars- Volume, are the numbers in the Hundreds or Thousands or just the regular number beside it. In attached pic it has blue line at -84 & green line at -168, so are they that number contract or -840(Hundreds) or -8400(Thousands).
[2021-04-30 20:20:05] |
The numbers are the actual numbers. This is true throughout the program. There are options throughout to display the data in a shorthand (Large Integer with Suffix) in which case you would still see the actual value, but you may see a notation of 'K' or 'M' after the number meaning it is in thousands (K) or millions (M). Refer to the "Large Integer with Suffix" in this section for more information: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-30 21:18:47] |
So on this attached chart, the numbers I drew a rectangle around represent that actual number, The blue line is 6455 and black line is 3547, so that the exact number of contracts?
Capturees.PNG / V - Attached On 2021-04-30 21:16:54 UTC - Size: 59.63 KB - 337 views |
[2021-05-02 19:18:52] |
Yes, those numbers are the actual numbers of the Cumulative Delta Bars.
[2021-05-04 22:13:43] |
So if CDB-Volume relates to Market/Aggressive Orders which one of the other CDB relates to Limit/Passive Orders?
[2021-06-04 08:29:57] |
There is not one.
[2021-11-17 16:42:10] |
I have a question about my setting for the CDV Study; I have it displayed as Candlestick Price Volume Bars. So will it display the Candlesticks based off the charts Price candles or the Cumulative Delta indicator info?
[2021-11-17 17:59:46] |
It will draw the candlesticks based on the Cumulative Delta indicator information. In this particular case, the Volume subgraph represents the same value as the Main Price Graph volume.
[2022-06-05 00:59:16] |
I'm trying to figure out how to add the Study(MgannSwing) to the Cumulative Delta Trades study, I want it to overlay the delta candlesticks while tracking the swings in the cumulative delta
[2022-06-06 15:20:10] |
Refer to the following: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-29 12:33:21] |
User422433 - Posts: 18 |
In the second reply to this post it's mentioned you can use the Large Integer with Suffix option for the cumulative delta bars but I don't see the option. Is there any way to use shorthand for the volume in this study?
[2022-11-29 18:47:11] |
Refer to the following: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
