Date/Time: Tue, 24 Nov 2026 16:40:46 +0000
Denali + the other feed
View Count: 1118
[2021-04-20 02:47:52]
User19165 - Posts: 346
Another data costs question...It is confusing for everyone that is why there are so many queries in this area lately.
Currently I am paid up for nearly a year under what was the advanced package 5 using your bar charts feed for trading the Hang Seng. I would also like to add in Denali feed for the CME group products and some research. I am confused what to do and what the costs are? Please advise.
Date Time Of Last Edit: 2021-04-20 02:48:07
[2021-04-20 04:39:07]
Sierra_Chart Engineering - Posts: 25476
What you need to do is change to Service Package 11. Pricing is here:
Description of Service Packages and Pricing: Multiple Month Purchase Discount
It is only a small amount more being you are paying 6+ months.
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
And then you just need to follow the instructions here:
The instructions linked above also explain how to change your Service Package.
Date Time Of Last Edit: 2021-04-20 04:39:49
[2021-04-20 05:41:44]
Thanks.
I would like it confirmed that this will in no way interrupt my current HKFE data subscription, as this is my daily bread and butter.
Under package 11, you are saying my total cost for both data feeds is $220.8 / 6 months?
Under package 12, what does MBO really give you in terms of sierra charts functionality? Like do any of the volume studies take advantage of this - iceberg detection, liquidity tracking indicator? Or is this only going to apply to the heatmap and that is all?
[2021-04-20 09:14:47]
No. There will be no interruption.
This is just going to be the cost of the Sierra Chart software and also the Denali data feed. Not the data feed you are using for Hong Kong futures.
Service Package 12 includes this functionality:
Market By Order Data
Date Time Of Last Edit: 2021-04-21 16:49:11
