Date/Time: Fri, 03 May 2024 17:57:35 +0000
Using Calculated Values SG11 to drive bar color using Color Bar based on Alert
View Count: 376
[2021-04-08 16:30:34] |
User277997 - Posts: 21 |
Having an issue getting this to work. I want to color the bar if SG11 is above a certain absolute value and can't get it to color. When I try to pull the value in SG11 to the chart using a Spreadsheet formula study (=ID#.SG11),I get 0.00000 across the board in spite of the SG11 value ranging from -30% to +30%. When I pull the values from any of the other Subgraphs in Calc Values using the spreadsheet formula study, I get a line chart corresponding to the calculated values...but not sg11. Anyone ? |
[2021-04-08 18:30:02] |
John - SC Support - Posts: 31355 |
Refer to the following: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
