Date/Time: Thu, 02 May 2024 17:46:09 +0000
[Programming Help] - How to use DRAWSTYLE_POINT_VARIABLE_SIZE? Getting strange painting and chart scale.
View Count: 774
[2021-04-07 20:19:12] |
User719512 - Posts: 227 |
I have looked at the docs at https://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle_PointVariableSize, and getting unexpected results. Is there an example for DRAWSTYLE_POINT_VARIABLE_SIZE, or does anyone have suggestions on how I am using this DrawStyle incorrectly? Example code below. I expected a variable sized point at the sc.Close/Last price. What I am seeing is points at F.US.EPM21 prices like 4072.200, 4072.400 and not 4072.25, 4072.50, etc. SCSFExport scsf_OSC_TestVariablePoint(SCStudyInterfaceRef sc) { SCSubgraphRef Subgraph_VariableVolume = sc.Subgraph[0]; if (sc.SetDefaults) { sc.GraphName = "Variable Points"; sc.StudyDescription = "Variable Sized Points Test"; // sc Control variables sc.AutoLoop = 1; sc.DisplayAsMainPriceGraph = 1; Subgraph_VariableVolume.Name = "Variable Volume Points"; Subgraph_VariableVolume.DrawStyle = DRAWSTYLE_POINT_VARIABLE_SIZE; Subgraph_VariableVolume.PrimaryColor = RGB(128, 128, 128); return; } // for testing, just generate a random number for the Size. // just take a remainder of time for size 1-5. int size = sc.BaseDateTimeIn[sc.Index].GetSecond() % 5 + 1; Subgraph_VariableVolume[sc.Index] = sc.Close[sc.Index]; Subgraph_VariableVolume.Data[sc.Index] = sc.Close[sc.Index]; Subgraph_VariableVolume.Arrays[0][sc.Index] = size; } |
[2021-04-08 06:50:11] |
User907968 - Posts: 802 |
Check the value format used by the study - Chart Studies: Settings and Inputs Tab >> Value Format Maybe include the following (or similar) in the SetDefaults block: sc.ValueFormat = VALUEFORMAT_INHERITED;
Also, not related to your specific question but, these lines both perform the same operation: Subgraph_VariableVolume[sc.Index] = sc.Close[sc.Index];
Subgraph_VariableVolume.Data[sc.Index] = sc.Close[sc.Index]; The first line is a shorthand version of the second (ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].Data[] / sc.Subgraph[][]) |
[2021-04-08 07:48:20] |
Thank you for the tip on the ".Data". I tried the setting for ValueFormat and the result is the same. Chart settings shows Price Display Format as "0.01", but I am seeing whole numbers on the price scale.
[2021-04-08 09:29:01] |
Yes, ok, most likely because you have display as main price graph enabled (sc.DisplayAsMainPriceGraph = 1;), so there is no price chart to inherit the value format from, in which case try manually setting the value format to an appropriate value in the study settings window.
[2021-04-08 18:20:57] |
Just discovered this does not work if the Graph Draw Type is Blank. My study started working as expected once I set the Graph Draw Type to non-Blank (Line, Stair Step on Close, etc).
