Date/Time: Fri, 03 May 2024 12:09:49 +0000
[User Discussion] - Different candles on 400T chart, on the same computer
View Count: 556
[2021-04-06 14:36:57] |
User492288 - Posts: 28 |
Hello I am having problems with charts data, different 400 tick charts, same computer, but candles completely different , please see attached image thanks |
400 t chart.PNG / V - Attached On 2021-04-06 14:35:36 UTC - Size: 272.91 KB - 173 views |
[2021-04-07 02:17:58] |
58LesPaul - Posts: 429 |
I would bet you have session times set differently.
[2021-04-16 15:12:16] |
Refer to: Working With Charts: Resolving Differences of Chart Bars Between Charts (Resolving Differences of Chart Bars Between Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-16 15:12:58
