Date/Time: Tue, 30 Apr 2024 15:24:57 +0000
[User Discussion] - Sending info on entry orders and closed trades for AOS running in another Sieera chart
View Count: 533
[2021-04-02 23:50:03] |
User39949 - Posts: 25 |
Does sierra chart allow forwarding of information about executed, closed trades and entry orders to another installation of sieera chart registered to another username? And how can this information be populated into the AOS parameter variables that will run in this remote sierra chart installation?
[2021-05-05 05:05:35] |
Sierra_Chart Engineering - Posts: 14154 |
Yes this capability is now supported with the new Simulated Trading Service: New Super Enhanced Trade Simulation Service It is accomplished by sharing a trading account with the other user. What is meant by?: AOS In concept all of the trading information would be accessible by ACSIL if the chart the study is applied to is set to the same Trade Account where the activity is taking place. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-05 05:09:20
[2021-05-06 02:19:30] |
According to the defined parameters, the AOS should select only some shared inputs and then trade them live. So, if I understood correctly, then in remote Sierrachart, the sharing of a trading account would be set to read-only and AOS would then, based on the available complete trading information, take only the input that would comply with the defined rules? |
