Date/Time: Fri, 27 Nov 2026 12:39:33 +0000
data service
View Count: 812
[2021-03-18 16:24:26]
Anapurna - Posts: 10
Hi, I'd like to day trade CL and GC, (on top of the ES and MES, which is working fine), as well as possibly M6A and MCD. I'm still a bit confused about which data feeds to upgrade and subscribe to with SC. Could you please clarify that for me?
ESM21_FUT_CME
MESM21_FUT_CME
Hi, I updated my data feed to include Denali and the relevant exchanges, which seemed to work. But now I get this message when I try to non-sim trade MES:
MESM21_FUT_CME order reject account (my amp account #) not found
I checked on AMP, my account seems fine
Thanks for your help
[2021-03-18 18:52:24]
The symbols that you are referencing are for the Sierra Chart Order Routing Service. You can not use that service with AMP. AMP should have you setup with CQG for your order routing. If you do not have any information from AMP regarding your CQG account, then you will need to talk to AMP about that.
Once you get the CQG information, then you will follow the Setup Instructions at the following link to connect your Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
After you complete the above setup, you will then need to open your Chartbooks and select "Edit >> Translate Symbols to Current Service". This will translate the symbols you have for your charts to match the CQG symbols. Refer to the information here:
Edit Menu: Edit >> Translate Symbols To Current Service
