Date/Time: Sat, 18 May 2024 14:10:17 +0000
[User Discussion] - Adding Value on TOP of Period OHLC Variable period
View Count: 472
[2021-03-18 01:59:59] |
User164231 - Posts: 278 |
Hi all, Is there a way to add value on top or below of these lines? I tried duplicating the study and change the drawing to Custom Value at Y, the problem is that it has a line memory that blocks some of the value on the left. tks. |
Untitled.jpg / V - Attached On 2021-03-18 01:55:50 UTC - Size: 11.37 KB - 175 views Untitled2.jpg / V - Attached On 2021-03-18 01:59:02 UTC - Size: 10.73 KB - 177 views |
[2021-03-18 10:04:15] |
58LesPaul - Posts: 429 |
In the study subgraph tab, to the right of color selection there is a Name Label and Value Label selection. Just check the box and select where you want the label to be.
[2021-03-18 14:50:23] |
It looks like what you are dealing with is just a drawing order issue. Refer to the following: Chart Studies: Study Display Order For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-21 08:46:16] |
thanks but It does not look like answering my question; (Documentation removed. We cannot provide further help.) Date Time Of Last Edit: 2021-03-22 14:07:16
