Date/Time: Thu, 16 May 2024 18:58:09 +0000
System problems
View Count: 382
[2021-03-09 16:03:26] |
User401511 - Posts: 33 |
Hi, Sierra chart is laggy and the hotkeys don't work. I read in the self help its more than likely a system problem, but i don't know how to fix either than try and update windows? any help would be appreciated. thanks |
[2021-03-09 18:28:13] |
John - SC Support - Posts: 31697 |
Refer to the following: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
