Date/Time: Sun, 28 Apr 2024 19:55:03 +0000
[Locked] - Notice: Market Depth Issue when using Rithmic in Newer Versions
View Count: 1666
[2021-03-09 12:18:54] |
We have had many reports of market depth issues when using the Rithmic trading platform service with Sierra Chart, in newer versions of Sierra Chart. We have looked into this and we did identify one problem and that is resolved in the latest revision of 2238. Update to the latest prerelease following these instructions if you are experiencing a market depth issue: Software Download: Fast Update Even if you are running 2238, update again because we made a change to this version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
