Date/Time: Sat, 18 May 2024 14:44:46 +0000
all charts same symbol in different timeframes are moving
View Count: 365
[2021-03-08 16:42:18] |
mrseho - Posts: 25 |
Hi, I updated my Sierra Chrat and suddenly all charts of the same symbol are moving if I click from the 5 min window into the daily or 30 min window. Can you please tell me how to deactivate it. Thx, Sebastian |
[2021-03-08 19:27:54] |
The first thing to check is if you have the Global Cursor enabled and the charts are set to be synchronized. Refer to the information here: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) The other thing to check is if the Charts are linked and have the Scroll Position linked between them. Refer to the information here: Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
