Date/Time: Thu, 16 May 2024 18:16:43 +0000
"Flatten" button does not work
View Count: 408
[2021-03-08 13:19:05] |
ssangha84 - Posts: 107 |
When I was on simulator, I clicked the "Flatten" button quite often to get out of a position and it worked fine. I've noticed that when I am live, it does not close the position. It just cancels the stop and take profit orders. And then I have to manually right click the chart to actually close the position. Why is this, and how can I get that button on the trade window working?
[2021-03-08 16:47:26] |
John - SC Support - Posts: 31696 |
Refer to the following: Global Trade Settings Windows: Hold Market Order Until Pending Cancel Orders Are Confirmed (Global Settings >> General Trade Settings >> General) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-09 13:34:22] |
So do I want this option enabled? I haven't changed any of my settings from my sim trading, and it seemed to work fine on that. Right now this option is disabled. The text is a bit confusing to me, I just want to get out of my position immediately when I click Flatten.
[2021-03-09 13:40:50] |
In the case of Transact you do want to enable that option.
