Date/Time: Tue, 30 Apr 2024 05:47:19 +0000
[User Discussion] - MACD
View Count: 978
[2014-02-28 18:41:48] |
bwalks123 - Posts: 122 |
I am using the MACD study and i cant figure out to get the histogram bars to plot behind the macd signal line and moving average line? Is there a way to change which parts of the study plot ontop/behind one another?
[2014-02-28 23:03:52] |
No. Studies do not provide this capability.
[2014-03-01 03:24:56] |
Sawtooth - Posts: 3985 |
You can use two instances of the MACD study, set to the same Chart Region. On the upper one, set the Draw Styles of the MACD and MA of MACD to Ignore. On the lower one, set the MACD Diff to Ignore. The order they appear in the Studies to Graph list is what allows this. The lower one will paint over the upper one. |
