Date/Time: Sat, 18 May 2024 16:14:37 +0000
Real Time Clock is not updating and will not delete
View Count: 780
[2021-03-06 13:55:25] |
User186889 - Posts: 53 |
Hello SC I have 3 charts that I normally have the Real Time Clock upon. I have REMOVED the clock from 2 of the 3 charts but it continues to display and is Frozen in time. My STUDIES field does not show the Clock at all - See attached files. How do I remove this?? (This is an error that occurs now and then and has done over last few years and is generally only removed by rebuilding the chart). Thanks - Mark B See attached files |
Dual VBP Very Simple V9A - 6 Mar 21.Cht - Attached On 2021-03-06 13:53:30 UTC - Size: 24.57 KB - 175 views CLOCK WONT DELETE AND WRONG TIME - 6 MAR 21.png / V - Attached On 2021-03-06 13:53:45 UTC - Size: 183.99 KB - 177 views |
[2021-03-06 16:45:45] |
Remove it through the Manage Chart Drawings window: Chart Drawing Tools: Manage Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-07 16:56:13] |
Hello Sierra - are you sure? Because the 'Tools > Manage Drawings' does not include the Real Time Clock or any other STUDY like MACD's, it is a tool for editing deleting lines etc. I tried adding a clock to another chart to prove the point - It does not work. Next suggestion please
[2021-03-07 17:19:09] |
Yes we are sure, and we added the Clock-Realtime study to the chart and then went to the Manage Chart Drawings Window and we do see the text drawing listed there.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-07 17:19:32
