Date/Time: Sat, 04 May 2024 00:32:20 +0000
MACD Study with Double Exponential Moving Average option
View Count: 412
[2021-03-04 12:02:44] |
User193492 - Posts: 2 |
Is it possible to have a MACD Study with a Double Exponential Moving Average option?
[2021-03-04 16:10:01] |
John - SC Support - Posts: 31362 |
You would just need to add the Double Exponential Moving Average study and then base it on the MACD study and set the Input for the MACD subgraph. Refer to the following: Moving Average - Double Exponential And refer to the following for the Based On setting: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-05 14:55:06] |
Perfect. Thank you!
