Date/Time: Fri, 03 May 2024 03:12:23 +0000
Switch CQG datafeed (AMP - CQG+sierra) to Advanced MBO + Denali Data Feed
View Count: 701
[2021-03-04 10:08:30] |
User440207 - Posts: 8 |
Hello Before, I used Sierrachart by AMP with CQG data feed. Now I am using Sierra directly through Sierra with subscription 12 - Advanced MBO + Denali Data Feed. Since the change, Sierrachart lagged a lot, is slowing down. The platform was working fine just before. So I don't understand what has changed. This is not from the PC (i think), as I have 64GB of RAM + an Intel (R) Xeon (R) W-2295 CPU @ 3.00GHz 3.00 GHz. On sierra, I am connected to the "SC Data - All Services data" service Would you know what could be the problem please? Thank you Antoine Renaud |
[2021-03-04 11:10:46] |
Since the change, The issue is unrelated to the change.Refer to help topic 30 for help with this: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-04 11:10:55
