Date/Time: Sun, 05 May 2024 09:39:56 +0000
Time Difference Between Different Symbols
View Count: 395
[2021-03-03 23:48:56] |
jj554 - Posts: 20 |
I'm using the SC delayed data feed and the times for different from one another. Currently, the hourly candle on the ZW symbol is 13:30:00 and the hourly candle on the ES is 18:15:00. I know the session start times will dictate when the bars are printed but there is a 4 hour difference in these two symbols. Is the data delayed at different rates for different symbols or is there something else going on? Thanks! |
[2021-03-04 14:53:47] |
John - SC Support - Posts: 31362 |
All of the data from the CME Group is delayed by 10 minutes and 10 seconds. Therefore, you should have the same times, unless your Session Times do not cover the same time periods. So check your Session Times first and make sure they are the same, or at least for ZW that they do not stop at 13:30:00 (which it sounds like they do right now). Refer to the information for Session Times here: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
