Date/Time: Sat, 04 May 2024 18:30:53 +0000
Synch drawings between charts
View Count: 565
[2021-03-03 21:12:58] |
User645832 - Posts: 99 |
I am synchronizing drawing between several charts (I have set references from each chart to all the other charts), my problem is that when I want to erase all drawings using the Erase All Non-Text Drawings tool I can only do it from the chart where the drawings were originated. Is there a way to setup this tool so it will be able to erase all drawings regardless of which chart I want to use it from? Thank you, |
[2021-03-03 22:30:49] |
John - SC Support - Posts: 31362 |
Refer to this setting: Chart Settings: Allow Modification of Chart Drawings from Other Charts (Chart >> Chart Settings >> Chart Drawing menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-04 01:26:22] |
What you want to do is not supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-04 01:26:28
[2021-03-04 06:10:02] |
What is the quickest way then to selecting all drawings on a chart and deleting them?
[2021-03-05 04:20:10] |
You can do this through the Manage Chart Drawings window: Chart Drawing Tools: Manage Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
