Date/Time: Mon, 29 Apr 2024 08:03:00 +0000
Alerts
View Count: 377
[2021-03-03 14:18:53] |
User72965 - Posts: 114 |
I don't get an alert{or notice when I switch from Live to Simulation trade. I think I choose to cancel all Alerts .. May have cancelled that too??? I do Get through INTERACTIVE BROCKERS>> " Order Filled:Cancelled ect. Can you send what to do <> Thank You Gene :) |
[2021-03-03 16:58:30] |
Refer to the following for the Alerts that can be set for the various trade actions and the following 4 items: Global Trade Settings Windows: Play Alert For New Order (Global Settings >> General Trade Settings >> Notifications) If you think you have disabled alert sounds, then refer to the following: Global Settings Menu: Mute All Alert Sounds (Global Settings menu) Also refer to the following for setting the alert sound for a specific alert: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
