Date/Time: Wed, 01 May 2024 06:46:42 +0000
Chart Header time frames
View Count: 597
[2021-03-02 19:49:17] |
bluejune - Posts: 34 |
The chart headers shows the Open, High, Low, Close for the previous candle stick Is there away for the chart header or chart to show the open, ,high, low for the the whole day. Note: I don't want to use quote board. |
[2021-03-02 20:18:32] |
John - SC Support - Posts: 31240 |
Refer to the following for what options are available in the Chart Header: Working With Charts: Region Data Line / Chart Header For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-02 23:27:20] |
There is also the Current Quote Window: Window and CW Menus: Current Quote Window (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-04 16:39:01] |
I am on the quote window page that you provided. I only see a way to custom the tools value and chart values window. I can not find a way to custom the "Current Quote Window" Is this possible? |
[2021-03-04 17:23:44] |
Refer to the following: Getting Quotes: Setting Fields to Display For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-05 03:18:12] |
The link in the above post is for customizing a Quote Board. Not the Current Quote window.
