Date/Time: Mon, 29 Apr 2024 16:10:48 +0000
TT order update Rejected , Account not found
View Count: 390
[2021-03-02 14:07:47] |
User867902 - Posts: 2 |
I have an account with AMP , they advised me to switch to CQG . how do i do that on the platform ? is TT dead ? Thanks |
[2021-03-02 16:33:10] |
John - SC Support - Posts: 31162 |
AMP has discontinued their connectivity to TT, therefore if you are staying with AMP and Sierra Chart, then the only option is to move to CQG for order routing. You can keep your data from the Denali Exchange Data Feed, it is only the order routing that would need to change. Once you have the information on your CQG credentials, then follow the instructions at this link for how to setup your Sierra Chart software: TT Based Order Routing Service: TT Interruption | Post: 252374 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
