Date/Time: Mon, 06 May 2024 01:08:11 +0000
Volume Profile for Bund comparison
View Count: 467
[2021-03-02 06:39:42] |
User135370 - Posts: 160 |
Hi Just curious, I set the same session times on Jigsaw TT and Sierra, the shape of the profile is very similar however there is a small difference between sierra and the other 2 I have attached an image There are several prices where there is a small difference in the total volume but if you look at the VPOC price 174.71 you will see the other 2 have a total volume of 823 and Sierra has a 796 Would you know why that is? Since session times are the same 08:00 - 22:00 CET and 01:10 - 07:59:59 CET they should all match |
[2021-03-02 06:40:43] |
I think I forgot the attachment, attached now
VP Disc.PNG / V - Attached On 2021-03-02 06:40:11 UTC - Size: 283.52 KB - 188 views |
[2021-03-03 03:51:35] |
Have you had a chance to review this?
[2021-03-04 15:33:55] |
This is not within the scope of our support. If there is any missing data in a chart, you can re-download it following these instructions: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart You need to use a standard chart to perform this procedure. And make sure to set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-04 15:35:08
