Date/Time: Mon, 29 Apr 2024 11:02:40 +0000
Sierra chart data feed disconnecting
View Count: 383
[2021-03-01 21:51:12] |
User346968 - Posts: 5 |
Hi, my Sierra chart data feed keeps disconnecting. The message log says "Disconnecting from data feed because usage time has ended. | 2021-02-28 16:18:14.886 *" It is true that my trial of service package 5 ended today, but I contacted AMP (my broker) a few days ago and they activated service package 5 for my account through their system.
[2021-03-01 22:06:09] |
The account that you have logged into this Support Board with is not paid for through AMP. This account is expired. If you have a different account through AMP, then you would need to log into your Sierra Chart account with that Account Name and Password.
[2021-03-01 22:17:10] |
Your broker AMP canceled your Sierra Chart account: 2021-02-26 22:36:59 ** Internal Reseller Billing canceled. Affiliate Code: amp AMP Trading Admin
At this point you need to directly pay for it. First restart Sierra Chart and follow the instructions below: Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
