Date/Time: Sat, 11 May 2024 05:56:15 +0000
Numbers bars coloring issues
View Count: 431
[2021-03-01 17:34:48] |
User202883 - Posts: 24 |
I'd like to color numbers bars based on bid/ask volume percentage and I'd like to color text based on diagonal dominant side bid/ask volume percentage. The issue is that sometimes the bars and the text are the same color so the text doesn't appear. Can different colors be assigned to the text and to the bars?
[2021-03-01 19:42:24] |
John - SC Support - Posts: 31534 |
Refer to this setting and the 8 settings after it: Numbers Bars: Use Separate Colors for Text Coloring Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
