Date/Time: Sun, 28 Apr 2024 04:17:06 +0000
Noticing Occasional Global Crosshair Lag After Update
View Count: 414
[2021-02-28 15:31:52] |
User414533 - Posts: 89 |
This isn't severe by any means, but it is noticeable. I have no lag or "hitching" on any other Window's application. I'm just wondering if there is a slight inefficiency in the Global Crosshair code now that can be fixed or maybe an incompatibility with some particular drawings/graphics? It kind of happens randomly and usually when I just start moving it. This NEVER happened prior to the last week or so. FYI: I also have the Tool Values window set to open whenever I click my mouse.
[2021-02-28 16:25:21] |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
