Date/Time: Sat, 04 May 2024 22:02:40 +0000
Color Bar Based On Alert Condition % offset problem.
View Count: 493
[2021-02-26 19:23:30] |
GravisHTG - Posts: 303 |
I have the last version of sierra chart. Just found out how plot arrows. Now i really want to have some offset in % but it just wont work. it work ok in TICK thanks in advance. |
arrow in percentage.PNG / V - Attached On 2021-02-26 19:23:02 UTC - Size: 50.87 KB - 183 views arrow in percentage 2.PNG / V - Attached On 2021-02-26 19:23:05 UTC - Size: 49.09 KB - 178 views arrow in tick.PNG / V - Attached On 2021-02-26 19:23:08 UTC - Size: 52.85 KB - 175 views |
[2021-02-26 20:04:48] |
John - SC Support - Posts: 31362 |
It does work properly. What you need to consider is that the Percentage is based on the price. In this case, you have a chart that has prices about 5.00, so 5% of 5.00 = 0.25, so the arrow would be placed at ~4.75. You just need to use a larger percentage, or stick with the # of ticks. # of ticks overall works better as the arrows tend to stay in a better position while changing scale. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
