Date/Time: Mon, 06 May 2024 10:26:36 +0000
How to migrate from Tradovate/CQG to Tradovate/Denali, Sierra Chart
View Count: 819
[2021-02-26 03:33:48] |
User471548 - Posts: 24 |
Hi, My broker is Tradovate and it provides exchange data and order routing through CQG. I trade futures on CBOT and need real-time exchange data with market depth from CBOT, CME, and Eurex. I would like to migrate to Denali data and Sierra Chart for order routing and still use Tradovate as my broker. What are the steps I need to take to migrate without issues? Thanks. |
[2021-02-26 14:54:59] |
John - SC Support - Posts: 31379 |
We do not believe that the Sierra Chart Order Routing service is available through Tradeovate. They would need to have support for TT, which we are not aware that they do. If that has changed, please let us know. Assuming the above is still correct, then the only thing you would need to change is your Data source, as you would still use CQG for your order routing. You would need to sign up for the Denali Exchange Data Feed and select the appropriate exchanges that you want. You would then just need to let your broker know to stop the data from CQG. Refer to the Setup Instructions for the Denali Exchange Data Feed for the CME Group here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* And also the separate instructions for the Denali Exchange Data Feed for EUREX here: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
