Date/Time: Tue, 14 May 2024 16:24:40 +0000
Trading with AMP
View Count: 553
[2021-02-18 17:25:27] |
Marmany - Posts: 303 |
Currently using the TT / Sierra Chart Order Routing Service with Denali Data. Spoke to AMP help desk and was told TT link would be re-instated for CME in a couple of days. Post #15 on TT Based Order Routing Service: TT Interruption - Support Board - Sierra Chart Implies that the only way to trade and AMP account will be with the CQG Web API. On further discussion with AMP Help desk was informed that in order to receive a CQG account username I would have to subscribe to CQG data. Your note clearly states it is possible to use the Denali data. I filled the AMP switchover form in, leaving the data feed section blank, several hours ago and have not received a CQG username and password. Would like to be able to resume trading, please advise how best to proceed. |
[2021-02-18 18:54:49] |
John - SC Support - Posts: 31608 |
You need to talk with AMP about getting this moving. They have to do the work to get you switched over. Once that is done then it is just matter of changing the service in your local version of Sierra Chart. Here is the link to the instructions to follow through this process: TT Based Order Routing Service: TT Interruption | Post: 252374 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-18 19:04:09] |
On further discussion with AMP Help desk was informed that in order to receive a CQG account username I would have to subscribe to CQG data. This should now be settled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
