Date/Time: Mon, 13 May 2024 21:48:00 +0000
Switching from TT to CQG - AMP
View Count: 703
[2021-02-18 16:59:39] |
aelagha - Posts: 31 |
I use Denali datafeed, SC order routing with TT and AMP account. I got the form to switch from TT to CQG from AMP. I also reviewed your post on the issue (TT Based Order Routing Service: TT Interruption), and that by completing this form, I will continue to use Denali datafeed but CQG order routing. However, the AMP form they sent indicates changing the datafeed to CQG datafeed which I do not want. I want to keep Denali. (https://clients.ampfutures.com/sierra-chart-live-trading-setup-request?utm_medium=email&_hsmi=111754947&_hsenc=p2ANqtz-_zeQRbHCojWEEkduwNrxZ-6R4BIYJHttImsDfp5FabVbG_Ti7EZFqMRinjZUYLQJl1uAwzRDNGXg9aa7rk6HBu4M9fjQ&utm_content=111754947&utm_source=hs_email) How can I switch to CQG order routing while keeping Denali? thx |
[2021-02-18 17:03:23] |
never mind. my mistake. it is the right form
[2021-02-18 17:05:04] |
User548030 - Posts: 25 |
It wasn't your mistake, they actually just changed it lol
[2021-02-18 17:11:36] |
lol...
[2021-02-18 17:16:20] |
@TRADE_YOUR_PLAN - Posts: 126 |
I'm actually in the queue with AMP chat over this very issue. Thanks for posting they changed the form. Their form did only provide for DATA FEED and not the current "Sierra Chart - Denali - CQG (No Data - Order Routing only) selection for the "Which Datafeed?" question. Reading this reply will help some users who filled out the form early in the process.
[2021-02-18 17:19:53] |
User401511 - Posts: 33 |
So is this a permant change until we manually go back to TT if we want? I read SC wants to move away from TT now.
[2021-02-18 17:49:25] |
for me, I think I will stick with CQG order routing till SC has its direct connection to CME, or another problem with CQG happens, and we switch back :)
[2021-02-18 17:52:45] |
Yeah this seems like the only good option here. The one thing I'm worried about is server side OCO will not be supported with CQG Web API until they have built an alternate connection to CQG. EDIT: I was wrong, server side orders supported Date Time Of Last Edit: 2021-02-18 19:42:41
[2021-02-18 17:53:54] |
How can I switch to CQG order routing while keeping Denali? thx AMP has told us, the form has been updated with the new option:"Sierra Chart-Denali-CQG (no data - order routing only)"
[2021-02-18 17:55:13] |
I read SC wants to move away from TT now. You can continue to use it for the foreseeable future but we are working on our own direct order routing so it will be secondary. And from the users perspective how the orders are routed in the background generally should not matter.
[2021-02-18 17:55:18] |
User852559 - Posts: 40 |
Does this apply if you pay for Denali through AMP and not Sierra directly?
Date Time Of Last Edit: 2021-02-18 17:55:30
